1 - 20 of 53 Posts
· Mule Barn Proprietor
thread i wanted to do for a while. We have the chapter truck pics thread, so lets to a truck specs thread!
Lets list all the info on our trucks, all the details that are or arent in your sig.
Chat a little bit about different setups you've had if you'd like:thumbsup:
Also, would be nice to include any dyno sheets and time slips if you got em! :thumbsup:
Discussion Starter · #3 · (Edited)
My truck
2002 2500 QCSB 2wd NV4500. Built 7/2002 (which may be the last month of 2nd gen production???)
Its been through some variations but as it sits right now:
-2006 vintage Airdog 100 with 1/2 lines from tank to pump, drawing through stock intank pickup. Stock LP and Fuel Filter housing deleted
-Valair 13" Kevlar/Ceramic Single disc clutch
-BD short shift
-Isspro EV1s pyro, primary boost, overall boost with LEDs
-Vulcan Fuel pressure gauge , and El cheapo Drive pressure gauge with soot trap
-TST COMP
-TS MVP
-6x.013s By Weston Shupe, cylindrical sac , 152* spray angle, 300 bar opening pressure, think there is a tiny bit of internal work done
-7x.011 microblind sac injectors by Altered Diesel Wurks, 285 bar
-.010 over stock 12v Cummins Headgasket
-ARP headstuds & Rocker studs
- Altered Diesel Wurks 7/16 .120 wall 10mm ball end pushrods
-12v tappet cover for improved crankcase breathing
-BD 3 Piece T3 manifold
-Hamilton Valve Springs
-Peak Intercooler Boots
-HX35 with hotside mods over a S475 (75/96/1.32 T6)
-4 inch straight exhaust
-Amsoil throughout
The truck has made 500hp/1000tq on smaller injectors(7x.010)
and run 14.5 @102 in the quarter on street tires, on a very lazy run.
has yet to be run all out on either the dyno or track :doh:
543/1208 in 4th , VP didnt like the stack i was running @ Little River Dragway
Favorite mod so far is definitely the injectors, although there are several other parts on it that ive been very very happy with
Truck is a 2007 5.9 4x4. It's a quad cab short bed.
Suspension: Stock but I have the rear leaf spacers and overloads pulled. This took about 2 inches out of the back and helped the ride quite a bit. Shocks are Rancho RS9000XLs.
Fuel: 60% over 5 hole 124* spray angle extrude honed remans from Jamie @ CPP. These are relatively smoky but they are really quiet and smooth. I have not experience any rattle with them.
Melted piston update: one injector was spraying way outside the bowl. Melted the piston, scarred cylinder.
Injection pump setup is the PPE Dual fuelers with a stock LBZ pump on top and a T&C 60% over pump on bottom. The T&C pump would not keep up with these injectors when I ran it solo. I was dropping rail pressure on very mild tuning. The dual fuelers have handled everything that has been asked of them.
Lift pump is an ADII 165. It's a non quick-connect setup and I've had no issues with it at all. It does sound pretty sickly sometimes though.
Truck also has a T&C wild rail with a 32k relief valve. Some people's eyes get wide at this pressure but it's there to protect the injectors in the events of spikes or malfunctions, not to run at that pressure all the time. It offers protection you don't get with a capped rail.
I didn't like the feed that came with the dual fuelers so I redid them in some braided lines with an fittings. -8 to dual -6.
Here's the Stock PPE 5/16" Tee next to my concoction:
On the truck:
Air: Stainless Diesel compound turbo setup. It's a polished stainless diesel t3 manifold. Turbos are a Bullseye 62/68/14 with a spring gate setup over a box stock 75/96/1.32 T6 borg warner. This setup has been fantastic for me. I highly recommend plunking down the extra coin on a Stainless Diesel setup if that's the only thing preventing you from purchasing it. All the piping and hot pipe lined up perfectly. They do not include a coolant line and transmission dipstick tube like MPI does. I'd give the edge to MPI in that category. You do have to bend A/C lines like most other kits. It wasn't hard to do. I pulled the passenger side battery and inner fender to aid in install. Spool is nice IMO but that's relative. I'll try to grab some videos of me playing around on the street eventually.
The transmission is a Garmon competition unit. It has full billet shafts and a billet triple disc converter from Precision Industries. The input is also from them it is 300m and cryoed. I don't know if that makes it a stronger shaft or not but it sounds fancy. It shifts pretty firm and very quick. I'm very happy with this guy.
Other doodads are an Edge CTS for gauges (dumped a full suite of DiPricols and ISSPROs for this thing and I love it), Hamilton 110# springs, A1 Studs, Aluminum rear driveshaft with spicer 1480s, Motorsport Diesel coolant bypass, 305/70/17 Nitto Terra grapplers, 5" Expandit exhaust (straight). I recently swapped the front ball joints for carlis. Truck tightened up considerably. I redid the stereo with a Kenwood Garmin Nav double din, Polk MM Components and a Rockford Power t400-4. Front doors are dynomatted and ensolited. I'd like to do the rest of the interior but that kind of stuff is on the back burner. I really like the Head unit. It has bluetooth pairing with your phone so you can make calls from it hands free by programming names into it. The nav in dash is nice too.
Weight is 7040#s with me in it. Best ET is an 11.85 @ 116.98. Comp D calculator says 764 rwhp with the MPH and weight. I haven't had it dynod since the new tunes and dual fuelers.
Here's an 11.89 pass at Cajun Nationals a few months ago this was a tune from Mike @ ATP. Kory Willis handles most of my tuning normally, I just didn't give him enough time to get me a good hot tune for the track that day.
I'm sure there's stuff I'm forgetting, but that's most of the major stuff. I'm working on getting some ladder bars put together and then I'd like to take another crack at the track. I think I can knock a little off the ET with a more aggressive launch without wheel hop. It was an issue that day.
I got an early 04 cclb 2wd "555" engine with an NV5600.
T409 4" turbo back exhaust, straight pipe. Banks CAI (junk) and Banks 3.5" ram-air. South Bend dd3250 with upgraded hydraulics. Smarty S06 pod on sw8. Never been to the track or dyno. I can tell you it needs more power though.
Sent from my iPhone using AutoGuide.com App
How you liking that clutch Dustin?
I love it. The dual friction material helps. I've noticed it smoother with 10k+ lbs behind the truck. The upgraded hydros are great too. My clutch pedal feels like my cousins f150.
Reactions: Capt. Slow
Family hauler: '03 F250 CC SWB FX4 Lariat, 7.3. Straight piped factory exhaust, Edge Evo HT, and a DIY Tymar CAI.
The heavy hauler: '93 D350 club cab. Stock clutch, stock intercooler, stock internals, and stock turbo (that's laggy as hell). Has a DennyT stage 2 pin, Diamond Eye 4" straight piped, BHAF, and a set of SDX 5x.012s.
If I don't sell her, the Cummins is going to get freshened up, studded with a new gasket, and a new turbo then it's going to replace the Stroke in the Ford.
Sent from my iPhone using AutoGuide.com Free App
My screen name suits my truck and my pocket book. It is flexible and fun to drive. I have three turbos but no time to mess with it all. Stay tuned.
Josh got ugly with me so I have to post more about my truck :hehe:
S&B intake
Crazy Carl's cold air piping
My own custom Dukie Pipe intake horn I built
Tunnel Ram intake plate
7x0.010" injectors
TS MPV timing box
gauges
Manual belt driven belt pump
inline fuel/water filter
Griffin all aluminum radiator
Custom multi rate front coils (yield 3.5" of lift)
Bilstein 5100 shocks
Thuren 3rd gen track bar
Thuren new design control arms
'08.5 Mopar steering
Custom rear leafs (yield 1" of lift)
Billet converter
Billet input
Billet flex plate
Built valve body
Lots of stuff done to the clutches, drums, bands, billet anchor, etc etc as far as the trans goes
Posi lock cable used on the front axle
37" tires
That is the basics and I have changed a lot of stuff up before that.
In the future
I have 3 turbos ready to build a triple kit with. 2 he351's and the hx35 on the truck
I plan on installing at least some 2.5 Kings later (shocks)
I have some Thuren shock towers in the shed
Edge Juice w/attitude with CTS
And I am sure there will be some other odds and ends.
VIDEO
Heres my dyno sheet... There is sooooo much done to this thing its unreal!!! Just call me and i will point you in the right direction!
Disclaimer: Sorry Josh & Mark i just had to do it!!!
Just what I expected from you Clay lol
Reactions: Rebel Horseman
Great thread Josh. Maybe I'll eventually have enough add ons to participate in this one. Lol
Hey Mark, good to hear that you like your CTS. I was considering gauges in this one but I liked the attitude monitor I had in my 07.5. Really like the CTS so that looks like its on my to do list now. Did you get the backup camera also?
1 - 20 of 53 Posts
