I have not been able to find any source for steel fod in the engine. Afterburn suggested that possibly gear damage in the timing cover. Since I was way overdue on the KDP (killer dowel pin) fix I pulled the cover. I have read about the gray rtv being a sign of the eom taking care of the kdp. I have the gray rtv. My kdp was flush with the case, no retainer. Factory fix or no, I don't know, so I will fashion a retainer. Check torque on reachable bolts behind the timing gears.
Back to the steel fod. I see no source in the gears, and ran a magnet everyplace I could reach in the case. Also ran it in every nook and cranny on top of the head, I found no steel.
My planned course of action now is as follows;
Remove all mains, to include the upper bearing shell, except #1, #4, & #7 to support the crank, .
Remove rocker and support for #3 and inspect for the click that I detect in the video.
Flush the oil galley, utilizing the #3 rocker galley. It should flow down, and front to rear in the rifle galley due to the slope of the engine. I plan to follow that with compressed air. Flush through the crank oil holes.
Reinstall #2 & #6 to support the crank, and remove #1, #2, & #7, including upper shell.
Repeat the flush & compressed air process.
Attempt to check for wrist pin slop and piston slap at the bottom of the bore.
Check journals for roundness.
Inject oil down the rocker galley for future lube.
Roll in new mains.
Roll in new rod bearings.
Adjust valve lash.
Replace water pump with new.
Replace front seal and timing cover, prior to the oil pan, to avoid chance of anything falling into the pan.
Replace the pan.
Roll in new mains.
Adjust valve lash.
Replace the pan.
