Perhaps it's because I am somewhat new to a manual transmission diesel truck, but I can't help but feel I'm shifting in completely the wrong spot. Typically I start in 2nd gear, rev out to about 2k, shift to third, roll through that to around 2k, and shift to 4th and the RPMs just nose dive and then whatever head of steam I had is lost... once the RPMs pick up to around 1500 it starts to move out again. I don't have any smoke which I guess isn't a bad thing, but everyplace says turn the starwheel until I see smoke... I've never seen any hahaha...
Am I shifting WAY too early? Do these motors want to rev out past 2k? Few quick details about the truck:
#11 Fuel Plate in stock position (prior owner), starwheel turned a bit (zero smoke on throttle tip in... maybe I need more turns?), AFC slid forward, and 5" straight pipe. I have a pyro gauge on the way, and the reason I haven't hardly futzed with it is because I simply don't want to burn things up while running around blind. Have new OFV, filter, prefilter, though I'm not sure if fuel pressure would have a big impact (got the parts for that too just have to get some free time to tap the banjo bolt).
Would I benefit from a few more RPM? I have 410s so the motor likes to rev out to begin with... thanks for the insight.
-J
