I am looking forward to your feed back.
I am also considering upgrading the converter in the near future.
Thanks
Thanks
They have a triple disk but I didnt get it.Do they have other torque converters for our 68RFE other than the twin disk converter that you are getting?
I think Goerend has a Triple-Disk converter, as well.Do they have other torque converters for our 68RFE other than the twin disk converter that you are getting?
...Which disk-count did you go with? Double or Triple?...
:thumbsup:...I got the twin disk they say it will hold way more power than the trans will ever hold...
Thanks...I didn't see that. LOL:thumbsup:
Sounds good! This will be my next mod.I got my Goerend converter yesterday! It look me 1.5hrs to install last night. First impressions love it. It feels like its actually putting power to the ground, feels just like a manual trans. It pulls so hard from a dead stop. I raced a Dmax last night he was running a PPE I waxed him. It was leaving a light I gave it alittle throttle to see it he was going to race and half way through the intersection he nailed and so did I and instead of just the converter just slipping and RPMing out she grabbed really hard and broke the tires loose at about 20mph. I had him by 3 trucks up to 80mph. You can actually watch the tach climb when you drive and see it drop just like a hand shaker! This is the best mod I've done so far! I love that I have solid pull in the first 4 gears now. I was always afraid to race in the lower gears because I would just walk right through the converter. Not any more!
She holds 5th and 6th great its the stock clutches that are weak after 530hp. Not enough surface area and they are to tight to add anymore. Suncoast is working on some new frictions and steel compounds to hold more power. Any time you have huge power the overdrive clutches take the abuse.Sounds good! This will be my next mod.
Let us know how she holds the tourque in the higher gears like putin it to in 5th or 6th.
Thats when these stock converters really hate it!:hehe:
I took it all the way out. It helps when you have a hoist and a trans jack.Seriously! If I didn't live so friggin' far away, I'd bring a case of beer and help you install mine when I get it.
He probably just disconnected the driveshafts and slid the tranny and T-case back.
I've got a rotarry lift and a high-lift 2-ton tranny jack but I don't do alot of tranny work on my stuff.I took it all the way out. It helps when you have a hoist and a trans jack.
Its not bad. First remove drive shafts. Then all the wires, shift linkage, and hoses. Then remove converter inspection cover(bottom of trans). Remove brackets on the sides and the top of the trans(trans to motor). Then remove the torque coverter access panel for the converter bolts right side of the trans(about three o'clock). Remove dipstick bolt that holds dip stick in trans. Then remove trans cross member. Place trans jack under pan and support trans. When you look in the converter inspection plate you will see a arrow behind the flex plate its about 7 o'clock that arrow needs to be lined up with the converter bolt. That way the bolt will be lined up with the hole in the access panel you removed earlyer( 3 o'clock on the trans.) Then remove converter bolts spinning the flex plate and lining each bolt up with the arrow one at a time. Once converter is unbolted remove the bolts holding the trans to the engine. Last pull trans back from the engine and lower and pull converter off(comes off easy) Then put about two quarts of +4 ATF in new converter and reinstall it in the trans. The repeat to reinstall on the truck. After its installed add trans fluid till full. Mine took a total of 7 quarts to be full when hot.I don't know if there is a sticky about TC install, but I would like to here a brakedown of the install process.
It sounds easy, but I have never done one.
