MIne did the same thing after i installed governor springs, used to start INSTANTLY but it turns over a little more. not 4 seconds though...more like 1-2 secondsAs the title says I just installed a #5 fuel plate and 90hrs injectors. The power is great, although the truck used to start right up after 2 seconds of turning the key over, now it takes about 4 seconds. Any suggestions?
Yep, thats the way mine is..push down the throttle just enough were you can feel it pull the cable and hold it till it starts she will fire every time at the bump of the key. it will take some getting use too but you will get it down..
yup yup, me alsoYep, thats the way mine is..
I just barely touch the pedali hear putting foot on throttle to start is really rough on the engine. any truth to it?
In neutral it is at the first mark below 1KWhere is your trucks idle at? It sounds like it may be a little low.
