1 - 10 of 10 Posts
I just bought my first truck, '04 2500 CC with 170k on it.
I was underneath it today and found a wire harness dangling near the driver's side foglight. It is NOT the foglight and I cannot see any harness missing it's other half. Any ideas?
im not sure about your year but I got new headlights on my 06 and my new headlights didn't have an amber strip. so one of my plugs is just left un plugged.
05 G56 4x4 - leveled on 35s, 5" exhaust, South bend single disk
Maybe the PO had and aftermarket light bar or extra set of fogs.
my 03 has this i believe as well it is suppose to be on the up and down cross member i guess you would call it just to the left of thehead light mine has a plug in it not connected to anything. always wondered what it was for mine has foglights as well
Its almost looks like your fan clutch plug. Its a bad design and if it comes up-clipped the fan will cut the wires.. a lot of guys just unplug it and run without the clutch. Only really need it in the summer with A/C running while stopped.
· Admin/Mod
Long ways away from Fan Clutch wiring and not enough wires.
Is your Washer motor hooked up?
Is your Outside air temp sensor hooked up?
To me it looks exactly like the Plug for Fog Lights, including the little nub that goes in the hole to secure it in place.
· Admin/Mod
Is this the one you are talking about?
It is the temp sensor for the overhead readout.
Not the same type of plug.
1 - 10 of 10 Posts
