Just bought a 12 valve block want 1000+ hp what to do?
2478 Views 11 Replies 7 Participants Last post by  ShadowTrooper
Im picking up a 12 valve engine next week to build it up over the next few years. I plan to have this engine be competition only. what internals should i run?
1 - 12 of 12 Posts
search function
10k and I will build you a short block.
What no monotherms?
No thanks ha. I am trying to figure out if there's a certain crank I should run.. What needs to be done to connecting rods. What heads are best. All stuff like that. I want to learn the engine by build it from bottom up
Pulling? Nitrous? It all matters....I made 972rwhp with big nitrous and 60psi with just an o-ringed head and studs. Nitrous is actually easier on engines than really big boost or rpm.
This is probably your best bet
I want to drag race. i want to basically build my engine so i can throw any turbo on it or anything else and not worry about harming anything within the block
you are to cheep for 1000hp.
What to do?.. Spend money.. You'll want a girdle, main studs, arp 625's with an o ringed, ported head, at least a benched 13mm pump with some wild injectors and dv's, and an expensive transmission, and if you don't want to break anything else, good axle(s) etc.
Plan on spending at least 10-15k, and that's on the cheap side.
1 - 12 of 12 Posts
