1 - 1 of 1 Posts
The Challenge of Power
Racine County Fairgrounds
Union Grove, WI
Saturday night June 7th
Start time 6:00 PM
8,000 lb Workstock Truck
8,000 lb Street Stock Truck
8,000 lb Super Street Truck
8,000 lb Super Stock Truck
8,000 lb Modified Truck
NADM is offering a wide range of classes in Diesel Sled Pulling, with a rule set permitting every level of diesel truck to compete from stock street trucks to full blown tube-frame Modified pulling trucks. All classes 8000 pound maximum unless otherwise noted. See class overviews below:
Work Stock: Stock appearing turbochargers, 1" minimum compression travel on rear suspension, water injection prohibited, hanging weights prohibited.
2.6 Street Diesel: Single turbo, 2.6 inch maximum inducer bore, turbocharger bushings prohibited, 1" minimum compression travel on rear suspension, water injection prohibited, receiver style hitch required, hanging weights permitted.
2.8 Street Diesel: Single turbo, 2.8 inch maximum inducer bore, turbocharger bushings permitted, water injection prohibited, bolt in, removable solid rear suspension bars permitted, receiver style hitch required, drive shaft u-joint shields required, hanging weights permitted.
Super Street Diesel: 3.2-inch maximum inducer bore in twin turbo configuration, unlimited inducer bore single chargers permitted, open driveline permitted, DOT tires required.
Modified Diesel: Unlimited turbocharger, 2 stage maximum, open driveline, open tire, 7600 pound maximum weight.
See RunNADM.com rulebook for specific class guidelines.
Bigger Purse! The Challenge of Power Sled Pulling Purses;
Modified Diesel :
700--500--300--150--100-
All True Modifieds that enter the class and hook, will receive $200 show up fee, and the 1st 5 will receive $500 instead of the standard $200.
Super Street Diesel :
600-450-300-250-150-100-75-75
1st 3 trucks that register will receive a $200 show up fee.
2.8 Street Diesel :
400-300-200-100-75-50-50-50-50
1st 3 trucks that register will receive a $100 show up fee.
2.6 Street Diesel :
300-200-100-75-50-35-35-35-35
1st truck that registers will receive a $100 show up fee.
Work Stock :
Trophy only
Other truck and tractor classes also. Two tracks of non-stop action!
Admission is $10.00 for adults and kids under 12 are free.
1 - 1 of 1 Posts
