I got a juice in my truck and was wondering if anyone has ran a smoke switch to it and the results and also and little input on how to do it would be nice. Thanks
TECH SPECIALIST
Yes I have one, and it works. Rarely used anymore with the cost of fuel.
15 mins or less to set it up. Take the map sensor connector on the JUICE side where it plugs into the block. Run a wire to the 5v power and another to the signal wire (The map has 3 wires so you will have to determine which two those are, I do not know for sure offhand). Put the ends of those wires to a toggle switch and you've got a smoke switch.
:thumbsup
I tried it and i guess it worked but i make alot more smoke when i just kinda power-brake it!!!
Not sure but i thought the theory behind it was to make the truck/chip think it has full boost, and when i did it, i got a constant 0 pounds of boost, and that seems wrong(zero boost reading) ...SmokingFords did it with his adrenaline and his pod says like 61+ pounds of boost....that seems right(full boost reading)....??
Just food for thought!!!:w:
thanks for all the help guys great results but one problem my boost gauge is messed up now sometimes it reads 0 psi then randomly it will jump up to 45 psi with the alert going off any help would be nice thanks
