is it possible to stack these two? i know smarty doesnt suggest stacking but they make the even numbers for is so we can what would be the restults other than a blown hg if its possible?
should be fine, i used to stack an adge with a superchips, theedge intercepts the parameters, anywhere it could make a change for the better , it did. works great
Reactions: CUMMINS FIREFIGHTER
Timing Timing Timing Timging....
Isnt always a good thing....
Might give way too much, and blow a HG for sure
It will only amplify what the smarty has already amplified.
Never should stack anything with a box that interprets a already modified signal
Guess what will happen....BOOM.... LOL I could go on and on....
I'm running edge race with the smarty, works flawless. I have the smarty on sw 3 and leave the edge at 0 (edge set at stock timing) unless I want a little extra passing power then ill bump the edge up a bit.
i would run my smarty on 8 with all default juice off unless i needed power then id flip it on
