OK, question 200 on this darn box!!
I finally got to taker her out for a few miles and right after I got going the alarm for regen pops on. I had to stop and when I got going again I was sure it would go right into regen so I hit the freeway. After driving 12 miles no regen so I turned around and came home.
When I left for work tonight again, it goes into regen. I was right in town so it was a few miles till the freeway. Before I could get to the freeway it goes back out!
Does this sound normal?? Is there some formula it needs to go to regen?? Kinda made me a little upset when I drove it to regen and it never went in!!
Chris
its normal, simple solution get the dpf delete, its more than worth it.
:agree2::agree2::agree2:
yeah it is easy... The dpf needs to hit 1500 degrees for it to go into regen... there are passiave regen, and the full regen. you are most likely seeing the passiave. which happens so you don't see the 70-80% cat full signs on the overhead.
its normal. Mine did that too, everyday when i was about 2 miles from home cruising a about 40 MPH it would come on. 2x a day minimum.
