1 - 2 of 2 Posts
jeep lift pump & walbro 392 pump
will the jeep lift pump setup work with a walbro 392 pump. will this remove the need to cut holes in the fuel tank or modify the lift pump? then if and when the walbro dies out in the middle of nowwhere, can i get home with the jeep lift pump. if you have an opinion of the walbro 392 pump, i would appreciate any comments good or bad.
i have a problem with the cost of the air dog and fass systems. i am trying to avoid being locked into a setup that is too specialized. i like generic and the ability to repair when off the main roads and not in the city.
thanks to the group
The liberty canister doesnt have a pump in it, and i was runnin a walbro pump at first and it was great! It ran very quiet and handled everything i was doin at the time very well! Also you need to look into adding a 2micron fuel filter, your injectors will love you for it.
1 - 2 of 2 Posts
