Alright, installed J/A about a month ago and truck ran fine. Last weak driving down the highway truck seemed to lose power and I noticed my egt's were like 700 one minute and then drop down to a low of 92. Got home and notced that the positve connection on the drivers side battery was loose so I replaced the end yesterday. Now today the truck ran great for a while but started idling rough and the egts were constantly at 100-200 degrees and seems to be back to stock power. Meanwhile not throwing any codes. Anybody had any similar problems or have any ideas. thanks
have you tried disconnecting both batteries and then reconnecting them?
GA CUMMINS CREW PREZ & Captain of the USS FAILBOAT
mine did the same thing, egts stayed low, then one morning i noticed a little power loss, went home let it idle, idle dropped check engine light came on, it was a p2149 which is fuel injector group 2 circuit harness open, mine had a bad fuel injector harnes on the juice would have been my guess, i took it off, and the truck ran fine, so right now its at edge being fixed... :thumbsup
My boost #'s seem to be normal, 7-8 psi and 70mph. I noticed in the morning my egt's are ok until I get off the highway after about 7 miles. When it comes down to idle at the stop, the egt's become erratic. Then on the way home my egt's are erratic the whole way. Then also when I get into the throttle a little bit, it sounds like its missing when it comes back down to idle again. I don't know what the deal is because it doesn't throw any codes and I don't even know where to start looking so any suggestions would be very helpful at this time. Thanks
