1 - 14 of 14 Posts
I have 97 3500 2wd Odo 222,000. Just rebuilt the transmission a couple weeks ago, put in new torque and ran all new trans lines and I've had nothing but issues since. Plugged in a scanner and get 3 codes: PO748, P1763, and P1757. When I try to accelerate from a complete stop, the truck starts shaking and doesn't want to move If I press down on the accelerator, the engine will rev and my rpm will spike . To pick up speed, I have to press on the accelerator lightly. If I press too hard, the engine will again just rev and rpms will spike . The truck tops out at around 50 MPH running 2500 rpms. If I try to press any harder on the accelerator rpms just spike. At first when I would ease off the accelerator I could feel the transmission shifting not sure now if it stays in 2nd or if it manages 3rd Willing to try anything at this point. I had a local shop check it out to see if they could pin point the issue, which then I was told they could not locate the issue and recommended that I retire the truck with all the issues going on with it
Sounds like the transmission is slipping. You may have cut a seal.
I appreciate giving me something to look into that's different than everything else I've been told
I would drop the pan and take a look.
Who rebuilt ur trans?
Me and a buddy of mine done the rebuild, he knew a little more about transmissions than I did so we gave it a go
Discussion Starter #8
I've had a few people tell me to look into replacing the governor pressure solenoid and transducer saying that could cause these issues.
Don't leave us hanging. If and when you figure out the problem or solution, post up and let us know.
Fluid smell, color? Next would be drop the pan and have a look. Might be something not requiring a full pull.
Discussion Starter #13
I do have what I believe is torque converter studder pretty bad. That comes from the clutches being bad or wrong fluid right? So could that be the cause of the rest of it?
1 - 14 of 14 Posts
