posting up a vid here for more exposure. some of u im sure have seen it in my other thread.
for those who dont kno...
i installed studs, springs, and had injectors tested at Superior injection and turbo, they installed the 100hp tips (bosch oem extrude honed) and tested injectors after the tips were installed. all checked out
put truck back together and it started fine and seemed to idle fine. put it in drive and it loped, put it in park and it stopped, then in drive and it loped again. figured maybe it was air in the system:confused013: BTW i did torque the connector tubes except for #6 but i do not have a starting issue or any white smoke at all
drove the truck lightly until it warmed up, hammered on it and blew a boosted connection. refastened..then did the same thing. then left the gate on 45psi till i got new clamps.
since then ive driven the truck a bit and here are my issues.
-seems a bit down on power but niot much, still builds boost easy
-lopeing, especially at first start only when put in drive or reverse. It now lopes when i decelrate to under ~20mph. tuning DOES affect this. its worse on the higher tunes
-heavy hazing on light acceleration and all the time on the highway (mayb this is normal for the bigger tips)
-lots of valve clatter/timing clatter under 10psi of boost (timing is down to lowest level on smarty) i have to check my lash again too
-when i rev it in drive RP hangs and comes back down all choppy and bouncy...best way to describe it is it sounds lik turbo bark out of my tail pipe and continues for a while after i rev it and truck surges during this time
i think thats it for now heres the vid. tell me what ya think
