1 - 19 of 19 Posts
Trying to decide which gauge to order. Already have triple pillar gauges with isspro egt, 0-60 boost, and trans. Getting ready to install AD II 165 system and want to do fuel pressure gauge at same time. Do i need anything over the 0-30 psi gauge?? Plan on ordering from dieselmanor with the isolator kit and installing on my steering column with an additional gauge.:confused013:
when i got mine they told me i didnt need anything more than the 0 to 30..
As everyone else has stated 0-30 is plenty.
Get the 0-30 and if your goin for anther one, might as well get a rail prs gauge too
Cost-wise it is about the same to go with the electronic EV2 fuel pressure gauge compared to the mechanical EV series with an isolator, and the electronic is a lot less hassle to install.
We also have the EV2 FP gauges available in 30 psi (R14033 for 3rd Gen Dodge match), and also with an integral warning light that turns on below 8 psi (R24033). These are brand new gauges and won't be on price lists yet, but the R14033 is the same price as the existing R14055, and the R24033 is about $10 higher retail.
Regards,
Michael Pliska
Regards,
Michael Pliska
ok. i was looking at the ev2 series online and decided that it was easier to go that way. i am thinking of a steering column dual pod with 0-30 fuel pressure, and rail pressure gauge as well , since i already have the triple pillar full. I have the ev one series on the pillar, just want to make sure they match and dont look goofy.
They will look very similar, but have three main visual differences:
EV series has convex curved lenses, EV2 has flat ones.
EV2 pointer hub is a perfect match for the factory pointer, EV just has a plain round pointer hub.
EV has the ISSPRO logo just below the pointer, EV2 has it just above the pointer.
I have run similar EV and EV2 gauges next to each other, and it is a minor difference in appearance.
Regards,
Michael Pliska
Discussion Starter #9
thanks. Are the ev2 just plug ins...or do they need fittings/ adaptors etc like my other gauges?
The EV2 fuel pressure gauge uses an 1/8" NPT threaded sensor. Most aftermarket fuel systems will have a port for fuel pressure, and it is usually 1/8" NPT.
The rail pressure gauge uses a harness which "piggybacks" on the factory sensor, you just unplug the OEM harness from the sensor, plug one side of our harness into the sensor, then plug the OEM harness into the back side of our harness (make sure you have it oriented correctly since it can be forced in backwards), then run the two wires and the power/ground/dimmer wires to the gauge.
Regards,
Michael Pliska
do the new gauges with the "fixed" center halos look more like the ev's? because I am kind of unhappy how different they look (but only at night) during the day they look just like each other
As far as the halo effect (light escaping from the perimeter of the pointer hub), I'd estimate that the amount of light is about 30%-40% of the original units. I don't have a Dodge match EV series handy to compare, but I think it is roughly comparable.
and can you guys still fix them if I send them out to you? and is there any charge?
No problem on fixing them, and no charge to you, aside from what it costs you to ship it to us. Most guys wrap in a layer of bubble wrap and stuff them in a USPS Priority Mail box.
vvv SOME PEOPLE'S KIDS vvv
I've got the 0-30 and it has only worked for a couple months. I got a new sending unit and repressed the wires back in the rear of the gauge and it started to work. I let the truck sit for a little bit while I was driving my other truck and now the gauge isn't working AGAIN!! It's frustrating that you spend money on something that has worked 30% of the time you've had it.. I'm about fed up with it!
Tech Specialist
I had the same problem, replaced the sensor with the new kit they sent me and no problems since. I will see when I get back home how its holding up, but so far no other problems.
Thats what I did too which it worked for about 2 months maybe but now it's not working. I might go a different route with gauges on my '99. I'm kinda disappointed after spending $450+ on 3 gauges and 1 not being worth a chit. I didn't buy them so I can keep sending back the sending unit every 2-3months :banghead:
1 - 19 of 19 Posts
