Is the 09 Intercooler efficient ??
519 Views 4 Replies 4 Participants Last post by  DodgeLuvr
You guys have taught me a lot about how to make these pickups run & I really appreciate that, thank you all !! :thumbsup: Can anyone tell me if that thin intercooler is any good, is it restrictive and does it cool the air enough, it is only 1 1/4 thick.
Depends on the power your making..... its efficent enough for stock power. its a shame they charge $25k plus and put the cheap stuff they do on these rigs, on my 06' and now my 08' i have put the BD intercooler on them, and it helped lower EGTS quite a bit!
K2 Diesel Performance : BD Power Cool-It Intercooler
That's a tough question. I've read on here that the 2008+ intercoolers are crap and can't cool down efficiently because they are smaller. But with the mods in my sig, I've never seen over 1500 degrees at WOT. And I've run it hard.
I'm not disputing that an aftermarket one is better - or that I'd see lower EGT's. But I don't think its as crappy as people say.
For me, I'd rather spend $1,500 on other mods first - like upgrading the CP3 and fuel system. Which is what I did.
· Smells like Bananas
But do you have one of the little bitty Inter Coolers. They made the switch in the 08 models so some have the good one and the others have the little ones
But if a person spends the money on a Inter Cooler I would use Joe Hellmanns, Hellmann Performance Intercoolers, custom fabrication richmond texas, hellmann performance richmond texas, custom fabrication, diesel truck, welding, diesel performance parts, texas, powerstroke
His are sweet and stout. Mind you there is a science to building a inter cooler. Really big and fast flowing does not make for a better cooler.
Money is the # 1 Priority to almost everyone, the way i see it is play it safe..... when you spend 25k + on a truck you dont want to blow it up, right? So here is the order in which i modded mine, if you care,
Boost, EGT, Fuel Pressure Gauges
Intercooler
Air Filter
Exhaust and XRT
Clutch
Head studs
Boost Fooler
150 Fass
MP8
to Come
K2's twins
WCC Intake
K2 boost tube
80hp injectors
Modified CP3
New clutch
I built my engine Safety first.
