You'll be fine without it plugged in.
do you have to set the timing to that or is that when its on towRunning the mini on the stock power level is asking for trouble not to mention it makes less power that the truck did from factory.
If you don't want a hp increase it should be ran on the tow setting with timing set at 2-3
Dave Mathews from DRACONIAN Diesel set up the MCC file for me. I dont know how he set up the timing but running the truck on stock has increased my MPG's (18.5-19.5 average) and I'd be surprised if it made less power now than it did before deletes, it just feels so much faster and stronger. I specifically asked to keep the tuning as close to factory settings as possible, my only wish was to keep the CEL happy and not compromise reliability.Running the mini on the stock power level is asking for trouble not to mention it makes less power that the truck did from factory.
During the initial download to your truck it will ask you what level you want your timing at 1-5. If you didn't change it it defaults to 3.do you have to set the timing to that or is that when its on tow
what should the timing be set to in order to run it on Stock setting?During the initial download to your truck it will ask you what level you want your timing at 1-5. If you didn't change it it defaults to 3.
The problem is the timing level stays the same but you are able to adjust the fuel amount (power levels). Timing set even at 3 is not a good combination for the stock power level.
Personally I wouldn't run it at all. If your dead set on it though I would stick to level 1what should the timing be set to in order to run it on Stock setting?
Setting 2 or 3So whats 2-3
No you have to go threw the instal process again. Remember default is 3 so If you don't remember changing it that's likely what its set to.is there anyway to find out what timing 1,2,3...it's currently set to??
Either will be fine
