Is DDRP enough?
526 Views 7 Replies 7 Participants Last post by  kstinson
I just did a search of previous threads and read about the ddrp pumps. I have a stock truck and just ordered a 4" exhaust and BHAF. Question is, I would like to upgrade pumps and the only other mod I want to do is add the Quadzilla Max Mileage module. According to the other posts, they say if you put a module on the ddrp won't be enough. However, if I understand this module right it just changes timing correct? So would the ddrp be good enough for me??
THANKS FOR ANY HELP!!!
well, it sounds like it'll work good for you, BUT, if ya ever decide to upgrade to a box that taps the pump wire, def upgrade to a Air Dog or Raptor...:thumbsup:
2003 Ram 2500 CCLB NV5600 4wd
I've got one I am going to sale. It's been on the truck for 2 months. It delievers 18-20 psi at idle and usually runs right at 15 psi running down the road. I am planning on doing some injectors and other things so I am going to put an Airdog on. If your interested PM me.
According to the Quadzilla Mileage Max information it will not raise stock boost pressure nor add any fuel, so I am assuming its a timing only box. So there should be absolutely no need for anything larger than a DDRP.
I found my information here.
Max Mileage Module for Dodge
