Im just trying something different. If anyone's running this stack what settings are you using ? It does have the Hot Unlock.
Smarty is crap without a stack. I had a TST with it at one time. Truck just feels lazy without it.Dont stack! Why r u wanting to stack?
Oh yea defiantly even #s.Use only even numbers on smarty if you do decide to do it.
Sent from my iPhone using AutoGuide.com App
My old set up just lit the turbos much faster. Its just real laggy and smokey.Smarty / TST is a more popular stack. Just don't use any added timing, weather it's an even number or not if you adjust options on the SO6 it will override the sw. Under your timimg options make sure it's set to default.
Also I think on newer models tst won't play well with our trucks..
WHAT!!! Ya i bet ur injectors hate u!! If u donr like smarty sell it and go get a banks! LmaoSmarty is crap without a stack. I had a TST with it at one time. Truck just feels lazy without it.
Banks.... HA
Ya it was a joke... lol u should get udc it will help out alot more!Banks.... HA.
I ran a 12.15 @ 113mph on lvl 3. There's a lot left in it just in tuning, with just a Smarty or lack there of. It didn't want to spool. Ive sensed moved TM to stock setting it spools better now. With it stacked it spools really fast.
I will in spring no one tuning it by me. I know a guy but 8hrs away.Ya it was a joke... lol u should get udc it will help out alot more!
Good to know what settings are you using ?Thats the stack ive used for 7yrs no problems if you pay attention
Noway I can run smarty that high. Way too much fuel 180hp sticks and duel pumps.Ive used them all if you set the smarty to factory timming it doesn't matter what you set it at,use caution with torque settings on the smarty unless youve done tranny work already if not it will be toast on auto and smoke the clutch on manual .i use 5 or 6 on smarty and 3 to 5 on edge depends on what im doing ive used smarty on 9 and edge on 5 for months at a time i just kept an eye on the gauges the edge gauges aren't that accurate when stacking use stand alones
