1 - 3 of 3 Posts
So I've looked all over for this and haven't found anything. I have never noticed but I just got my iquad setup and noticed when I got on it there was a warning. I took a look at it and it was my boost psi. It's actually reading higher than my mechanical gauge says by a pretty good amount. I'm also having time getting over 40 psi with my new twins setup and wonder if this has something do with it?
Discussion Starter · #2 ·
Anybody have any ideas? Is there a way to check my map sensor to make sure it is working correctly?
Check the middle wire on the map sensor for voltage. Should be pretty low around .6 at idle and climb steadily with boost.
Make sure you are looking at the parameter that is the little turbo symbol.
The next version actually pops the name of the parameter up when you select it but, it is a few days out still.
1 - 3 of 3 Posts
