Hello everyone! Let me start off by saying my name is Chris and also thank you for letting me be a part of this forum. I currently run an '06 3500, auto trans single wheel SLT quad cab. For the most part this truck has been very good to me, up until just recently... which I will get into shortly. As far as any mods go the previous owner has put just about every product BANKS makes for this and also put on some aftermarket LED's in. I have not put any modifications on, the only thing I've done is put plow connections on. I did however "modify" my low beams to run on the fog light switch because the was the easiest and cheapest thing to do at the time.
Now, my issue(s).....
I have no speedometer, no instrument panel lights, interior lights and I don't think the heating element is working either, at least I'm not seeing the dash light come in when starting.
So, here's what my dumbass did. While working on ball joints and brakes my stupid left the key on and killed both batteries! I threw the charger on overnight and, just for what I thought was good measure turned the charger over to the 200A start assist. Truck fired up like normal, got down the street and lost all electrical, volt gauge was almost in the basement.
I've load tested the batteries and I got a new alternator and everything seemed to work fine, as far as charging goes, but am left with the above mentioned issues.
After putting in the new alternator I DID have interior and panel lights, but my headlights would flash off & on at random and still had no speedo. It wasn't until we popped the TIPM cover that I lost interior and panel lights. We did find a loose connection running up to the aftermarket visor lights and put a better connection, my head lights haven't flickered since but everything else still doesn't work. I've also noticed that my fuel DTE is all retarded as well showing a significant distance reduction when compared to the fuel gauge.
Well, thats it, what happened, what I've done, what's been done before me. I know these are electrically temperamental but PLEASE if anyone has any info, some direction to point me in please do so, before I burn this MF in the driveway! I don't wanna do that cuz I don't have GAP insurance, but it's getting almost to where I'll take the loss!!
Thank you in advance for any help you can give.
Chris
ps.- sorry for the novel length post
Chris
