1 - 16 of 16 Posts
I have an 04 3500 5.9ho, and I keep getting an intermittent p0336 code, it'll go away some times and come back. I've replaced the sensor 3 times now, and it still has a problem, my only thoughts are it's the harness, tuner or (hopefully not)ecm, any insight? The symptoms are it just misses every now and then, starts fine and runs alright for the most part just a little rough now and then, almost like a lope.
Trying to learn
Really need some truck details to be able to help. Auto/manual, mileage, and any mods to start with.
Fill in a Sig, click on account details on the upper right side of the screen, then click on Account Settings, then scroll down the left side of the screen and click on Signature.
Be sure you have 2 good batteries 12.6V and the terminals are clean and secure.
Return to stock tuning, if running a tuner
List any other symptoms - black smoke, white smoke, hard starts, etc.
Loose connection or chaffed wire.
Manual nv5600, 269k miles, has a tst powermax tuner (installed by previous owner) and a airdog lp, when it's throwing the code it can start a little rough but not terrible, no smoke or anything outside of usual connection at harness should be fine I don't know if the harness is chaffed elsewhere, I haven't returned to stock tuning when the code pops up, could that help?
Also batteries are both pretty new and connections are pretty good. What is a signature, and why do I fill that out? I'm a cummins forum noob.
Trying to learn
It puts your truck info at the bottom of your posts, which knowing makes it easier to help with questions. See mine below
Ahh ok, well I made a reply with the info you requested, I've done some research on this tuner and it bridges between the CKP and cmp sensors, as well as the injectors harnesses, seems mega sketch to me, I may be upgrading to an edge soon because of that
To avoid throwing parts at issue should go thru diagnostics ;)
When Monitored and Set Condition:
P0336-CRANKSHAFT POSITION (CKP) SENSOR SIGNAL
When Monitored: With the key on.
Set Condition: The voltage detected at the Crankshaft position sensor is below a
calibrated value.
POSSIBLE CAUSES
CKP SENSOR
(G17) SIGNAL CIRCUIT OPEN
(K6) 5-VOLT SUPPLY CIRCUIT OPEN
(K167) RETURN CIRCUIT OPEN
(G17) SIGNAL CIRCUIT SHORTED TO (K167) RETURN CIRCUIT
(K6) 5-VOLT SUPPLY CIRCUIT SHORTED TO (K167) RETURN CIRCUIT
(G17) SIGNAL CIRCUIT SHORTED TO (K6) 5-VOLT SUPPLY CIRCUIT
(G17) SIGNAL CIRCUIT SHORTED TO GROUND
(K6) 5-VOLT SUPPLY CIRCUIT SHORTED TO BATTERY NEGATIVE
INTERMITTENT CONDITION
ECM
TEST ACTION APPLICABILITY
1 Disconnect the CKP sensor harness connector.
NOTE: Check connectors - Clean/repair as necessary.
Measure the resistance between the (K6) 5-volt supply circuit and the (G17) signal
circuit of the sensor harness connector.
Is the resistance between 900 and 1100 ohms?
All
Yes ! Go To 2
No ! Replace the CKP sensor.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL).
2 Disconnect the ECM harness connectors.
Measure the resistance of the (G17) signal circuit between the ECM harness
connector and the CKP sensor harness connector.
Is the resistance less than 10 ohms?
All
Yes ! Go To 3
No ! Repair the open (G17) signal circuit.
3 Measure the resistance of the (K6) 5-volt supply circuit between the ECM harness
All
Yes ! Go To 4
No ! Repair the open (K6) 5-volt supply circuit.
4 Measure the resistance of the (K167) return circuit between the ECM harness
All
Yes ! Go To 5
No ! Repair the open (K167) return circuit.
5 Measure the resistance between the (G17) signal circuit and the (K167) return circuit
in the sensor connector.
Is the resistance greater than 100k Ohms?
All
Yes ! Go To 6
No ! Repair the short circuit or replace the engine harness.
6 Measure the resistance between the (K6) 5-volt supply circuit and the (K167) return
circuit in the sensor connector.
All
Yes ! Go To 7
7 Measure the resistance between the (G17) signal circuit and ground.
All
Yes ! Go To 8
8 Measure the resistance between the (K6) 5-volt supply circuit and ground.
All
Yes ! Go To 9
9 Measure the resistance between the (G17) signal circuit and the (K6) 5-volt supply
All
Yes ! Go To 10
10 Reconnect the ECM harness connectors.
Ignition on, engine not running.
With the DRBIIIt, erase DTCs.
Connect a jumper wire between the sensor supply circuit and the sensor return
circuit in the sensor harness connector.
Did DTC P0337 set?
All
Yes ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
No ! Replace the ECM.
Discussion Starter #8
calibrated value.
POSSIBLE CAUSES
CKP SENSOR
ECM
All
Yes ! Go To 2
All
Yes ! Go To 3
All
Yes ! Go To 4
All
Yes ! Go To 5
All
Yes ! Go To 6
All
Yes ! Go To 7
All
Yes ! Go To 8
All
Yes ! Go To 9
All
Yes ! Go To 10
Did DTC P0337 set?
All
Procedure).
That's pretty in depth lol, honestly to skip that I'd just replace the harness, it's pretty rough and I've found multiple wires that were expossed so it'd probably be worth my time and money just to replace the whole thing, the problem is I just can't fine an engine harness anywhere online, if you guys know where I could get one I'd greatly appreciate it for for sure, but honestly I've been doing research on the tuner the previous owner put on the truck, and it's the type that plugs in to the injector harness, ckp harness, and cmp harness, it's a common type but it's probably 15 years old and it changes tunes on its own occasionally and with the intermittent nature of the code it may just be causing a communication error, but either way if that don't fix it I need to find a harness, I appreciate your help
Trying to learn
Most everything electrical on these trucks is in-depth. Amazes me as to how so many different systems can seem to, cross-contaminate, and cause symptoms in other things.
I would try disconnect/remove tuner to rule out. Get simpler modern tuner that uses just reliable datalink, ie Smarty/ HP tuner.
As far as harness, not sure where you are going to find a OEM harness(es) , get lucky find NOS, or good one in junk yard, Otherwise Painless Wiring is possible option they make some for swaps.
Discussion Starter #11
As far as harness, not sure where you are going to find a OEM harness, get lucky find NOS, or good one in junk yard, Otherwise Painless Wiring is option they have them at +/- $800 Painless Wiring
Yeah there's says it's not suitable for oem replacement though, so not sure how that would work, it's way to difficult to get something that goes out so often on any vehicle
Discussion Starter #12
So I recently had a no start situation with it, map code, i ripped the tuner off and haven’t had an issue since
The TST Powermax was never that good nor popular for common rails when it came out in 2004.
It is an extremely intrusive and complicated interceptor type module that connected to a ton of engine sensors.
IMO, no one should be using a TST Powermax these days, nor any type of interceptor module.
Discussion Starter #14
So
so what tuner would you recommend for a replacement? I was looking at the edge cts2 possibly.
So
I would need way more info on your truck, what you use your truck for and what your goals are before I can make a recommendation.
This tuner's website has some good info and options for the 2004.5 model year.
www.mm3tuning.com
I am not associated with him nor do I have any of his products.
Discussion Starter #16
www.mm3tuning.com
its bone stock with an airdog lift pump, just for some fun, not a race truck or anything, just something simple plug and play, not interested in efi live or any custom tunes
1 - 16 of 16 Posts
