1 - 10 of 10 Posts
hi guys im new to the forum I have 2005 dodge cummins 5.9 that has 420klm im having issues with dead pedal (cuts in and out) rpm spikes in park at idle! the cold start fast idle feature cuts out prematurely! when driving truck and pedal starts acting up sometimes i pull over shut of pull key restart and its like nothing happend! recently swapped the apps sensor with pedal and did the reset and no change! any help would be much appreciated !
:welcome:
Check for codes,ECM and EMIC(cluster)??, usually wire/connection issue .:wink2:
when i go click on the 2005 its soooo slow i cant go up or down the page cant do anything!! not sure if its my laptop being dated with windows 7 !!
It has nothing to do with Windows 7. The entire FSM is over 8000 pages. Best option would be to download a local copy onto your hard drive. Might have to run overnight, but once you have a local copy, you should be able to access it relatively quickly.
1 - 10 of 10 Posts
