Has anyone else ever had anything similar happen? I've just started having this issue where I'll have intermittent dead pedal issues at 55 mph, give or take a few miles an hour. I drop down to 45 or speed up to 65, and it drives perfectly fine. Usually when it happens, if I lift my foot off the pedal and then get back on, it'll respond again. Also doesn't seem to happen when I'm giving it enough to actually accelerate, it only happens when I've got the pedal down just enough to maintain my speed.
While I haven't actually got the truck scanned, the only code I've had on the odo readout was a p0500, which has since gone away. The APPS was replaced with a timbo APPS roughly 6 months ago. No signs of any issues with the VP44, it's always been fed good pressure. No white smoke, truck always starts good, it'll rev up to 3200 RPM under load no problem.
Only thing that I've noticed is that on the data logging part of my iquad, sometimes it'll readout speeds that aren't possible. I kept it running tonight on an hour long drive and it said that my max speed was 169 mph. That's obviously not possible for these trucks with an NV4500 and 3.54s. It also appears that the vehicle speed jumps around some in my data log, it'll go from a constant 60 to 80+ mph and then back down to what the actual speed is. Could this be related to my dead pedal issue?
I hate to start another dead pedal thread, but the only condition that constantly causes it is vehicle speed, and I spent several hours researching and found almost no information on anything similar.
