Wonderful first post, but I was told that if I wanted answers, this was the place to post!
Just got the lift pump and the injection pump replaced on my 01.5. They did the updated in tank lift pump. 200 miles after this work, the truck started flashing an intermittant ABS light, blinking on and off at different rates. Truck will miss occasionally, sometimes so violently that it will make the seat belts lock. Other times, it will go a hundred miles with no ABS or miss. No codes. They cannot tell me what is wrong with it, as the computer wont show them anything. They tried assuming that my dash module is bad, as initially I got a NO-BUS code with a wacko speedometer and some other lights, but now it is just back to missing and ABS. Also, the miss seems to come under light throttle, and sometimes you can barely feel it, but as I previously said, sometimes it will rattle your teeth.
Anyone else experience anything remotely close to this? You're help would be greatly appreciated.
Aaron.
Aaron.
