Intake heater relay??
1013 Views 4 Replies 3 Participants Last post by  joshland
Ok so I had to replace my fender and I believe it's the intake heater relay that's bolted on jut below the driver side battery box, now it has the small wires that go onto small little bolts I believe there just grounds but mine fell off and I'm not sure which one goes where? There is 4 of them! Or does it matter which one goes where! If someone has a wiring diagram of it or knows what colour goes where that would be great!
The 4 wires are paired in two's. One wire in each set it a hot from the ecm and the other is a ground. Just put each set of wires on 1 set of relay studs....you're correct, polarity doesnt matter
So as long as the pairs are together side by side I should be fine?
yes, so long they are matching pairs
Ok thanks guys
