1 - 4 of 4 Posts
Alright guys I'm having an issue with my 07 5.9. The truck starts and drives fine, the problem is that my instrument cluster will stop working sometimes (all of the gauges are dead) then as time passes they will come back on slowly one by one. Lately the truck has shut off on me out of nowhere. I have checked the codes and got a list of about 10 codes!! I am no expert on the electrical side of this but I'm pointing towards the TIPM being faulty. I've read a little bit about the function of it and seems to me like it is the one causing all of this. I would like to know if anyone has had this problem before and what the fix was. I just don't want to dump $800 on a new module and that not be the problem. Here are the list of codes I pulled
P2269: water in fuel
P2509: ECM/PCM power intermitten
P0462: Fuel Level sensor low Voltage
P0532: A/C pressure sensor low voltage
P0483: Cooling Fan Speed
U0001: Can C Bus
P0234: Turbo Overboost
U1412: VSS Malfunction
U0121: Communication loss Antibrake Module
U0141: Communication Loss FCM
Any help is Appreciated.
I would check all grounds and connections under the hood before diving into the TIPM too far, bad ground straps or corroded connections will do bad things, especially when the computers are bolted to the side of the engine...
If you don't have much luck with answers here, you might post in the non-powertrain section
Thanks bud. Yea that's going to be my next step. I also forgot to mention that my passenger side battery took a not to long ago. when I was replacing it, it was really hot like about to explode. I don't know if that had something to do with it. but I haven't had the same problem after installing my new one.
A hot passenger side battery often indicates a bad cable between the batteries positive posts (runs on top of the radiator). May be time to re-do some connections.
1 - 4 of 4 Posts
