Being that the MP-8 is only about $360 and Injectors are close to $1000 also 80 HP vs 100 HP of the MP-8 the decision is simple. Plus i believe before you get the full use out of the injectors you will need to address fuel delivery, as in a lift pump (FASS or Airdog)
I thought when stacking programmers, the output of one of them was limited?
Also, wouldn't the benefit of the programmers be greatly enchanced if the injectors are allowing more fuel to be delivered (in addition to upgrading the fuel delivery)?
I completely see the benefit of spending $360 vs $1,000+. But I also don't want to leave a lot of power on the table because I can't deliver enough fuel.
My goal is this: build the truck so I can use it as a DD, yet take it to the track and be able to run high 12's (12.99 is fine with me lol). I've read tons of literature, read this (and other) forums daily, and I see about 10 different ways people say to build a diesel. Some say upgrade the electronics first, then intake, exhaust, injectors, turbo and tranny. Others say intake, exhaust and tranny first, then use the power-adders. I'm sure all are good ways, but my needs and wants aren't to turn this into a 11 second truck.
My plan was this:
1) Intake
2) DPF and EGR delete (programmer to clear error codes)
3) Built tranny (Suncoast or ATS - ATS is testing one right now)
4) PMT or Edge (haven't decided yet)
5) 80 hp injectors
6) FASS fuel system
7) Snow Performance Stage 3 kit
The goal is to get rid of the EGR and DPF so I don't go through 3 sets of turbos, keep the programmer on stock to clear error codes, until I can upgrade the transmission. Once that is done, then I'll dump more fuel into it and keep the EGT's under control with the Snow Performance kit.
My guess is with these modifications I'd be in the 500 rwhp range, and at that time may upgrade the intercooler.
I'd probably leave the turbo alone since I don't want to make more than 500 rwhp.
