1 - 20 of 21 Posts
is it how the picture is taken or is the top of the stack leaning just a little bit to the back? It looks like it but then again how the picture is taken it could be an optical allusion(sp?)
Lookn good!
· low life
it hard to say..lol..........but my driveway is on a bad hill so that is prolly the problem
could you send me a couple of close up pics of your traction bar brackets.
That is fine i was just trying to figure out how you placed them.
· low life
Discussion Starter · #12 ·
yeah no problem....mine measure 69in from end bolt to end...and i hit the rearend straight inline with the frame..
Ok thanks. i am still trying to figure out how i am going to do mine because i have airbags and the brackets are in the way. My truck is also a long bed so mine will be a little longer.
· low life
Discussion Starter · #14 ·
Right, after looking and measuring everybody's else's.....i knew i wanted the them to be in a straight line...with the frame to keep the strengh....so i got under the truck about middle of the cab there is a c-nocht where the frame in welded into each other, thats where i welded my tabs "thinking it had to be strong there becasue of the double metal" i also read you want it to be like your drive shaft to keep the angles right
thanx, i will prob be finishing mine up sometime in the next month i hope.
man I like those track bars who made them I would probaly give 350-400 dollars for a set that beafy
Looks good!
1 - 20 of 21 Posts
