sounds like you have a small boost leak, you should at least make 18psi when you hammer it. check all the connections good, make sure there isnt a pin hole in the line to the gauge, and retighten all fittens after making a run, vibration can loosen them.I installed my Isspro mechanical boost gauge last night and took it for some test runs. I followed what everyone said on this forum and others where I take the bolt out of the manifold under the intake tube and put in the adapter that came with the gauge. Everything is all hooked up but what I don't understand is why the needle never gets off 0psi while normally driving, and when I floor it in 3rd or 4th, the highest it goes is 11psi then drops back down to 0psi. Is this normal for the H1C with the 21cm exhaust housing? I wouldn't think so with how I can hear the turbo while driving yet I'm not building boost (according to the gauge).
