1 - 9 of 9 Posts
I just bought a repo truck. It feels like it MAY have a tune in it, but not sure... Do I need to have the dealer install a stock tune into it before I do a smarty s06 tune download? I have the smarty in my hand just waiting for a reply
Thanks
The smarty carrys the dodge program. You should be good to go.
Thanks
if it has a modified tune loaded the Smarty will not work, it HAS to see a stock tune. If it won't load because of the modified tune, Bob Wagner can get you a recovery file so you can get the old tune out and load the Smarty
Learn something new everyday.
Edit: it even says that in the instructions, to make sure it is a stock program before installing the smarty.
Worked great, just trying to figure out what level is best now, thanks alot!
Is that streetable and does it smoke a ton? I have tried all the settings and if I floor it off the line they all smoke like crazy I really do not want to smoke that much if possible
I was mostly kidding!
i have found the best way to keep smoke down is to keep the torque at 1. i have a pretty tight converter, doesn't smoke much if i'm gentle, and i have 90's and twins.
1 - 9 of 9 Posts
