Inst. cluster lamp replacement
515 views 2 replies 3 participants last post by  JWH_03_Dodge
How do you access the back of cluster to replace the bulbs?
#3 ·
you'll have to remove the panel that the headlight switch is installed in, as well as the center dash panel.
After you remove both of those, remove the top 2 screws that hold the instrument cluster bezel in place, and remove the cluster bezel.
There are 4 screws that hold the cluster in place. Remove these. pull the cluster out and disconnect harnesses to get the rest of the way out.
hope that helps :thumbsup:
