Is the data on the Insight as good as guages? I'm perfectly OK with digital. But I want it to be reasonably current and accurate.
And will the Insight do the Turbo-Timer?
If it is then I should probably consider an insight. If not then guages.
I don't *need* any more HP (sure I'd love it but if I wanted to go fast I would have bought a sports car). I probably won't do DPF delete for a while, by which time the code free should be out and reliable so I don't need to clear codes. So I have a hard time justifying the additional $600 ish for a Juice w/ Attitude.
I think I should at a minimum have boost info and EGT. But the other values would also be interesting so I'm leaning towards the insight. Thoughts?
