Input shaft Questions
708 Views 4 Replies 3 Participants Last post by  ykdave
Hey so been doing some thinking, (i know Bad idea) but Could one change the spline count on a G 56 input shaft to get better highway speeds , sort of like changing the gear ratio of the input shaft, anyone shed some light on this for me , or if they already do it, did a search, but come up with nothing of substance !
Thanks
Bump to the top , no input at all ?
Keep thinking!
If you change the spline count, you need a different spline count on the clutch.
I had an employee once who wanted to grind a tooth off of his pinion for more power.
He also removed the check ball in a auto trans rooster comb as a shift improver.
Yes he drives on the same roads as us.!!!!!!
after some thought I figured that, it would be like a rear end, cant just change the pinion gear, have to change it all, and glad to know our roads are safe :)
keep thinking... LOL
Their is no gear ratio in the input shaft. its 1:1 with the engine regardless of it being a 10 tooth or a 20 tooth spline into the clutch disc, or 1-1/4" or 2" shaft diameter. unless your slipping the clutch, then its less than 1:1 :hehe:
if you really wanted to get crazy, you can get custom gears cut for the trans, or just change the rear end gears
