I thought I remembered hearing that you don't really need injectors for the 3rd gen cuz the stock one will flow ALOT. Is this true?
Stock common rail injectors can handle in the 500s...so there are other parts, like the transmission, lift pump and turbos that I would take care of before the injectors.:thumbsupI thought I remembered hearing that you don't really need injectors for the 3rd gen cuz the stock one will flow ALOT. Is this true?
cp3's go from $1200+, what are your plans for your truck, maybe you could look at the arson cp3 kit from Shane at wicked diesels, it will support 600hp, I have one and love it.What can you get a cp3 for $$ Do you just add that one on or what?
Brian is right. Ive met others in Texas with over 660HP AT THE REAR WHEELS on stockers.:thumbsupThe 04.5 up trucks can make some pretty good power with stock sticks. Luken made over 600 with stock sticks and CP3 with an 05.
