1 - 17 of 17 Posts
Im wondering what performance injectors would be good. My truck is stock right now and im going to eventually be getting a chip. But I figured since I may have to replace them get more power out of it. Any ideas would be great.. thanks
Wyoming Eastern President
I would suggest a lift pump first then gauges then chip then injectors/turbo
one of my injectors went bad so i figured i might as well make improvements and replace them all i installed my gauges about 2 weeks ago to keep an eye on egts boost and my transmission temp. i forgot to mention that in the signature.
Oh ok then, what are your plans for the truck?
But a lift pump is a must.
Not to jack your thread bobo, but I just ordered the airdog 150 and some new injectors. Is it necessary to pop test the new injectors? thanks in advance!
if you're not into "extreme" a set of 50s or 75s will serve you well, most all brands will get you an mpg increase if you don't go nuts.
Reactions: bobosRam2500
im tryig to bring up the horsepower and torque up because i eventually plan to enter it into races and tractor pulls.
I say order up an airdog or fass, and some 150s then a good 62 turbo
And depending on where you get the injectors you do not need to pop test them, as it has already been done
Discussion Starter · #9 ·
thankyou i will look into that
On call 24/7
If your looking to pull with it then your gonna have to go big. Its alot of money to get into pullin. You need to add a fuel pressure gauge to your gauges too.
Discussion Starter · #11 ·
i found a set of 110 ddps that im thinking about getting for now
seems you are extreme! lol
Discussion Starter · #13 ·
haha not to big lol i may go with 75s not sure yet gonna get the injectors and fass at the same time though
On call 24/7
The 110's would be good but you can get pretty good injectors for less money.
Discussion Starter · #15 ·
what company do yall recommend to go with
On call 24/7
I have heard alot of good things about farmboys diesel injectors. They are amlost half of DDP.
Discussion Starter · #17 ·
ill take a look
1 - 17 of 17 Posts
