I had some injectors tested that I was having trouble with. They are popping at 5k. How much pressure can the vp44 create and what would be the result of the injectors firing at such a high psi.
Thanks.
NOTE: I just heard back from the guy I bought these from. He said that they are supposed to be set at 5,000 psi. Why on earth would he do that?
Late delivery and shortened pump life. Looks like if they can test them, they should also be able set them. 300 Bar, works well.
Thanks for the reply. Yeh they can fix them but its $20 each. I'll just see if the seller will correct the settings.
Mopar1973Man.Com
Yeap it seem a bit high compared to the FSM for injector pop pressures...:w:
I added this to my first post, but thought I would add it here also.
I just heard back from the guy I bought these injectors from and he said that they are supposed to be set at 5,000 psi. Why would he do that?
