with all the mods in my sig what should i add next ? injectors or a pressure box ? and what brand and size ? thanks
Sticks! I used to get high rail pressure codes with a modded CP3 and pressure until I got injectors... and the power difference was great!
I bleed diesel
A nice set of injectors around 100 HP would be perfect for you right now.
You got that II stage 2 so I would do some injectors.
Dragfalcon, I was woundering how the 64 was spoolin with the stock sticks?
there is a little lag,in the bottom, but not as much as you would expect---as soon as it hits about 12 psi hold on cause its on after that:peelout
