1 - 4 of 4 Posts
Does anybody know how to test the injectors on a 94 dodge diesel. Has a miss around 1700 rpm so wondering if injectors or maybe injection pump?
the only sure fire way to test them is to take um out and get um pop tested, but you can take an open ended wrench and crack the the injector lines while its running, do um one by one, once you crack it just a little, you should be able to hear the engine get rough and die down a little, if you have a bad injector and you crack it and no change that would more than likely be the culprit..you can do the same on the pump side, just crack the lines from the IP..if no change once its cracked their could be some problems in the pump
1 - 4 of 4 Posts
