1 - 20 of 21 Posts
Would a super b with some 75 to 80 hp sticks be a good setup? My buddy just bought a 92 and wanted me to help him out with some performance mods he already has the fuel pin and all that good stuff done so far. Thanks for any help
HP goals??
Up to 600rwhp is pretty well scienced out.
He just wants a good DD setup prolly nothing over 400 hp
ya and he will want you know all the suporting mods clutch or torqe converter, electric or mechanicall pump probably studs you know all the suporting things
sorry it double posted
Yea the supporting mods are covered for now he is just looking into turbo and injectors so would the super b and some 75 to 80hp injectors be sufficient enough im new to the 1st gens and just trying to help him out, what's a good setup for around 375 to 400hp with these trucks?
Do you know how much HP the Super B will add? People have dynoed with just pump mods and got 250HP and 500 FT/LBS of TQ so with 80HP sticks would be around 330HP.
if you asking about injectors i would recomend some sdx 5X14's ( 140hp ) there $500 heres a link tell me what you think SDX III
or if you want a little smaller go with the 90 hp sdx injectors (stage II)
Discussion Starter #11
Would either one of them injectors go good with a super b?
What size is the Super B?
i dont know much about the super b but if you tell us the size like caseyf said that would probably let us tell you or at least help you more.
Discussion Starter #14
Its a 57/65/14
well i think either will work but the 5X14 sdx would probably be a good choice if you want my advice
Discussion Starter #16
What size injectors are those?
I wouldn't go with that turbo, an H1c upgrade would flow more air than it. A 57/65/14 isn't much bigger than stock. Look into getting a 60mm turbo and the 5x14's.
5X14s ( 140hp) and i wouldnt do a 60 mm upgrade for you money your better of getting a he351cw
whoops misread that he wasnt talking bout the upgrade but still think about a he351cw
for that kind of power you are going to need more turno than a super b and a he351. a s-362 would be the way to go and some 5x14's obviously all of the supporting mods if its an auto converter, a good rebuild with good clutches steels and so forth , and a shift kit is a must IMO. also a good lift pump and posibbly head studs if he wants to run it all out
1 - 20 of 21 Posts
