i pulled an injector and it had 635 on it, oring very hard. I called dap and john said they were the cheapest aftermarket (chinese ) injector you could get. He said to get vp7x8vco injectors with bosch bodies, for 325.00. Said that it would be around 400hp, i dont know much about that but do you guys think these would work good for me? Im going to wait for some advice before i order and thanks a bunch
fyi, i just bought this truck and it has bd hotrod pump, i think 150gph lift pump, hx40w turbo and quad adrenalin that may or may not have issues. thanks for the advice!!!
Well,
I think the injector he is staring is the 7x.0080 (40hp over stock, roughly)...or a 7x.0085 (75 hp over stock)
In terms of 400 hp, that is a combo of all your goodies turned up.
Ok thx for the help. Given my trucks upgrades should I go ahead and get the 50hp or the 75hp injectors? Thanks
I personally would go with the 75's unless you haven't done anything to the trans.
I like mechanical parts over electronic tuning.
Rather than push the part past its map, use it as designed.
The electronics should fine tune...not over tune.
I agree I could do without the programmer. I think I'll take it off and go with 75s thanks!
