So the old 07 5.9 is starting to make some oil and smoke white at morning startup. Currently has a set of BD 33% injectors. They are just outside of the 24 month warranty, of course. Wondering how I should proceed to test? It runs and idles fine so a shutdown test might now show what I need. I was thinking a cap off test and then let it sit over night and see if it still smokes in the am. Just do this one at a time and see what happens. I would prefer to just replace the bad injector/s as this set already cost me $2700. Otherwise, I will pull them and send them off for testing.
If you are making oil you either have a cracked injector or bad cp3 shaft seal.
If it's an injector, you should be able to remove the valve cover and see it spraying fuel. Just be careful because of the pressure behind it.
May have to unhook the FCA to see it, again just being mindful the system will be under 26kspi of pressure.
As for the smoking white, it could be the same injector if it's an injector leaking, but may not be. Will definitely have to do a cap off test to find it otherwise.
Related Threads
Cummins Diesel Forum
8.8M posts
379.7K members
Since 2005
A forum community dedicated to all things Cummins Diesel! Originally founded for owners and enthusiasts of Cummins powered Dodge pickups, the Cummins Forum has expanded to include ALL Cummins Engine applications! Come join the discussion about reviews, drivetrain swaps, turbos, modifications, classifieds, builds, troubleshooting, maintenance, and more!
