1 - 4 of 4 Posts
On leave I am thinking about doing twins(r-700's unless I am convinced otherwise), springs, and studs. I figured, depending on the cost of everything, I might as well do injectors as well. My overall goal is 650-700rwhp. I was thinking 90hp sticks, but is that a little small? Also what brands have people had good/bad luck with?
i dont think you would be able to spool twins without some bigger than stock sticks, but that could just be me? I'd go at least 90's if your gonna have twins.
A Couple Diesels
90's are very good- with large twins you can go bigger as well but could be smokey at idle. Flux injectors are supposed to be less smokey.
I would check out MPI or Wicked Diesels twins
I don't like my BD twins... my .02
1 - 4 of 4 Posts
