1 - 10 of 10 Posts
I saw a video on youtube a step by step teardown and cleaning of injectors but cannot find it. Can someone lead me in the right direction? Thanks.
Super Moderator
Even if you was to tear them down to clean them in order for them to be right they have to be POP tested.
If your having injector issues I would just get a hold of Eric with The Humgry Diesel for a set. That is my plans here real soon as I have 220,000 on the stockers and I just added a he351cw to the mix.
Kevin
xxx
Super Moderator
It's really easy. 15mm deepwell, a vice, 15mm wrench and lots of brake cleaner. Now putting them back together is different. You have to torque the body to 28ft-lbs. Do them all exactly the same. I just did my old set and a set I put the new nozzles on. Cheap old pop tester I got for 79 bucks and 3550 to 3600 psi. Got some .15 hardened shims off eBay too. Everything works perfectly. Way less than the $400 they want for 6 stock injectors.
1 - 10 of 10 Posts
