Injector Question
583 6
A buddy of mine is upgrading from 90hp injectors to 180s and is giving me a pretty good deal on the 90hp tips. My question is with what I have in my signature should I go ahead and install them or wait until I can get more parts like turbo, Arson III, lift pump, etc? My smarty is always on 3 and i tow a 24ft car trailer and car about 2-3 times a year. If I install them now how will EGTs be? Thanks in advance.
I'm waiting to do injectors till after I do my lift pump. Then maybe a Arson 3 then injectors. That's just me though. I would like to know what some one else's .02 is. Good question though. I'd be carefull on the egt's part. Might get a little warm towing.
fass or airdog 150gph, Transmission needs build up & your cp3 will eventually need some upgrade's soon........
if you have the extra $ laying around & can easily afford to buy & then hold em for a while go for the 90's !
Cant afford to do tranny right now thats why Smarty stays on level 3. So even on level 3, 90s will be hard on my stock cp3 and lift pump? I was kinda thinking I wouldnt notice much of a difference on a lower setting other than more smoke and warmer EGTs with stock turbo. Correct me if Im wrong...still learning.:cbadge2:
What Is the power gain with on level 3 of the smarty? If you put 90hp injectors in couldn't you just take the smarty off until you have the money for the trans upgrades? I would for sure upgrade the lift pump If you do decide to put those sticks in just me .02
