i know you should have them pop tested, it is not epensive, but i have also heard of some people getting away with not doing it to. I wish i could help you out, but i have never done nozzles before.
can you even pop test electronic injectors??
if you dont pop test your injectors you can get different opening pressures. witch will make the truck run like crap.
:thumbsup:can you even pop test electronic injectors??
Yeah, well kinda, you are really only looking at the spray pattern, opening pressure is constant since they fire off electronic solenoids
if you dont pop test your injectors you can get different opening pressures. witch will make the truck run like crap.Correct:thumbsup:
Should be able to:confused013: Pop tester is a pop tester is a pop tester...the injectors are in an '01 not the '03 in my sig, and can any cummins garage pop test them? There are several shops around me that work on big Cummins just wondering if they can do something like that.
not really anyone can pop test injectors with the right equipment but do they have the knowledge to actually set them correctly most injectors sold on the market arent set correctly i reccomend any set off injectors you buy takin to a reputable shop and retestedShould be able to:confused013: Pop tester is a pop tester is a pop tester...
Yeah, I guess I was assuming we were talking about a Reputable shop.....:S:not really anyone can pop test injectors with the right equipment but do they have the knowledge to actually set them correctly most injectors sold on the market arent set correctly i reccomend and set off injectors you buy takin the a reputable shop and retested
Take the top nut off, 10mm, pull out old nozzle, put new one in, make sure holes are properly lined up, tighten nut. All done. Make sure no dirt at all gets into the injector.anybody have a link on how to change the nozzles?
