With the stock turbo I'd say 5x.011s which is a 100ish hp stick. And with the aurora I'd say 5x.014 you need a egt gauge before you add anymore fuel and you probably need to set the timing on it. It'll pick up a lot with just advancing the pump timing to 16.5-17* degrees.
