Is it making oil? And if I had to replace them I would at least go with 50 horse injectors instead of stockers. Or get the stockers honed after they're inspected.
I have not done injectors yet so I haven't really studied up on them all that much. There are going to be a ton of brand loyal guys and some will actually know the difference between the injectors out there. Me I would just use the search button and read up on them. You can only use injector's for 03'-04' years IIRC unless you have an 04.5' (then you're looking at 04.5'-07......I think)? If my injector's went tits up on me tomorrow ( which would suck cause I couldn't afford to fix them :hehe: ) I would get some 90's or somewhere in that range because I know eventually I am going to add more air with a bigger turbo or turbo's. If you aren't sure about that then a small increase over stock would be the best bet. Unless you feel like belching smoke everywhere and running hot then get whatever size you want.what are signs of making oil? what brand 50 hp injectors
yepoil level increasing in crankcase
