What rghavana said^^^
Before you put REAL new Bosch or BBIs in.
Also run compression and leakdown tests on the cylinders. Just so you have a baseline for motor condition.
Have the ECU programmed back to stock at the dealer, never know who's Dog Shhittee DieCummins-Slop programming is in it. Immediately after you get it running>to the dealer shop for stock reprog.
Is the RPRV OEM Bosch? May be an aftermarket high pressure unit. Replace with one out of a real Bosch parts counter stock room ASAP before running. Or is it capped? Real Bad JuJu
Before you do damage to that expensive Cummins by sucking in dirt/dust, put an OEM stock factory air intake/filter box on it and do away with that leaking boy toy garbage.
The stock box is dirt tight, never leak and with the Wix 4" filter will make up to easy 500hp all day long with the right motor parts. Don't mess with shhittee you know nothing about.
